[GRASS5] Re: G_index, G_strstr, G_trim_decimal
Markus Neteler
neteler at geog.uni-hannover.de
Thu Jun 8 06:49:37 EDT 2000
On Wed, Jun 07, 2000 at 11:38:31PM +0200, Andreas Lange wrote:
> Hi developers,
> i am desperately searching for information about the functions G_index,
> G_strstr and G_trim_decimal. They are used in some of the sites modules,
> but nowhere documented (not in the 5.0 or 4.2 programming manual).
> I think the documentation should be added to the manual.
> Or are there any reasons why they should not be used?
Hi Andreas,
thanks for notifying about functions not yet described in PM.
I found:
src/libes/gis/trim_dec.c
int G_trim_decimal (char *buf)
/* this routine remove trailing zeros from decimal number
* for example: 23.45000 would come back as 23.45
src/libes/gis/index.c
char *
G_index (str, delim)
-> mhh, is it comparing str and delimiter?
char *
G_rindex (str, delim)
-> what's this?
src/libes/gis/string.c
* string/chring movement functions
* G_strcpy (T, F) copy F up to null, copy null
* G_strncpy (T, F, n) copy F up to null or n, always copy null
* G_chrcpy (T, F, n) copy F up to n, copy null
* G_strmov (T, F) copy F up to null
* G_chrmov (T, F, n) copy F up to n
* G_strcat (T, F) cat F up to null, copy null
* G_chrcat (T, F, n) cat F up to n, copy null
* the -cpy and -cat functions are for null-terminated destinations;
* the -mov functions are for non-null-terminated ('chring') destinations.
* all functions return 'T'.
* G_strcasecmp(a, b) char *a, *b;
* string compare ignoring case (upper or lower)
* returns: -1 a<b; 0 a==b; 1 a>
* G_strstr(mainString, subString)
* Return a pointer to the first occurrence of subString
* in mainString, or NULL if no occurrences are found.
* G_strdup(string)
* Return a pointer to a string that is a duplicate of the string
* given to G_strdup. The duplicate is created using malloc.
* If unable to allocate the required space, NULL is returned.
src/libes/gis/chop.c
* G_chop - chop leading and trailing white spaces:
* space, \f, \n, \r, \t, \v
* - returns pointer to string
* char *G_chop (char *s)
* modified copy of G_squeeze(); RB March 2000
* <Radim.Blazek at dhv.cz>
Shall I include a "utility" section within the programmer's manual?
Where to place these information?
Suggestions are welcome.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
