[GRASS5] Compile Grass 5 on Win 32
John Huddleston jhuddles at rocky.itc.nrcs.usda.gov
Wed Jun 7 08:02:11 EDT 2000
Mike,
Do the 'cvs update -A' and you will get the files
updated.  Remember to redo the configure again
though, as it will replace many of your files with
the ones in the cvs.  The big one is src/CMD/head/head
The first time it happened to me, I couldn't figure out
what had happened.   Then I realized that there
are default files in the system.  I am still working,
did more yesterday afternoon after posting the
000606 build.
John Huddleston
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Wednesday, June 07, 2000 3:16 AM
Subject: Re: [GRASS5] Compile Grass 5 on Win 32
> Hi Markus.
> >On Wed, Jun 07, 2000 at 12:06:48AM +1000, Mike Thomas wrote:
> >> Thats unfortunate, as the 1.1.1 distribution GPF's all the time!  Maybe
> I'd
> >> better stick to binary distributions.
> >For the non-U.S. citizens: What's GPF? :-)
> General Protection Fault - writing to memory it shouldn't - I can't
remember
> the exact error messages.  I'm Australian BTW.
> >> The XDR problem turned out to be Gmakefiles which did not use the
XDRLIB
> >> macro.
> >Please tell me, which modules still require XDRLIB to be added.
> >Then I will fix asap.
> Here's some.  Sounds like John may have got them already:
> /usr/local/grass-5.0b/driver/HTMLMAP
> /usr/local/grass-5.0b/etc/bin/contrib/cmd/v.build.polylines
> /usr/local/grass-5.0b/etc/bin/contrib/cmd/v.in.atlas
> /usr/local/grass-5.0b/etc/bin/main/cmd/v.llabel
> /usr/local/grass-5.0b/etc/bin/contrib/cmd/v.out.atlas
> /usr/local/grass-5.0b/etc/bin/main/cmd/v.out.idrisi
> /usr/local/grass-5.0b/etc/bin/main/cmd/r.direct
> Thanks for the help - I look forward to getting a working version of Grass
> up and running.
> Mike Thomas
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
