[GRASS5] Re: Windows grass binaries / GRASS branching
Markus Neteler neteler at geog.uni-hannover.de
Mon May 29 13:59:44 EDT 2000
Hello again,
(sorry for so many mails)
On Mon, May 29, 2000 at 04:01:13PM +0700, Justin Hickey wrote:
> Hello Markus
> On Fri, 26 May 2000, Markus Neteler wrote:
> > The only problem is the
> > src/CMD/lists/GRASS which is parsed for compilation. Either
> > we have to hold two lists (stable/unstable) or the compile
> > mechanism needs to be modified to
> >  1. ignore non-existing modules (as they might not have been checked
> >     out if the stable version was acquired)
> >  2. ignore compile errors and proceed, maybe collecting the
> >     names of uncompiled modules in a log file.
Both I could manage easily by modifying
src/CMD/generic/GISGEN.sh
Now "error.log" is created locally, containing such messages:
Compilation error at STEP: src/raster/r.cost (ignored)
Compilation error at STEP: src/raster/r.sss (ignored)
(Note: the r.cost error is a fake, no need to become nervous)
This means we can keep the full
src/CMD/lists/GRASS
list. The user could compile even if having only a sub-set of
modules (in case GRASS will be shipped in packages).
So: Shall I apply this patch?
Best wishes
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
