[GRASS5] Poll to remove XGRASS from source
Markus Neteler neteler at geog.uni-hannover.de
Mon May 29 13:39:18 EDT 2000
On Mon, May 29, 2000 at 09:53:19AM +0200, Bernhard Reiter wrote:
> on sun, may 28, 2000 at 02:17:25pm +0200, andreas lange wrote:
> > it will be sufficent if the xgrass code is stored in a tarball (outside
> > the cvs!). no separate repsitory needed.
> i agree, but it will stay in the repository anyway. at least in the old
> branches (and then in the attic directories as john will certainly explain
> us.  ;-) )
Dear developers,
the XGRASS is "cvs removed" from the repository.
This saves more than 6MB (source code).
But, if desired, you can still access it using an old tag:
 cvs -z3 co -r "release_grass5beta7_20_april_2000" grass/src/xgrass
No changes have been applied to XGRASS since 20_april_2000.
Best wishes
 Markus Neteler
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
