[GRASS5] Re: patch and CELL questions
Carl Anderson
candrsn at mindspring.com
Sat May 27 02:41:00 EDT 2000
grass at gen.knu.ac.kr,
in GRASS5
the response of
d.rast map=spot.image bg=black renders as greyscale
is not the same as
d.rast map=spot.image bg=red renders as color
when using the GRASS4 colormap
The differring responses do not occur with GRASS5 colormaps (both
render as color)
The spot.image tested is from spearfish/PERMANENT
Tracking of the "bug" will have to start in
src/display/d.rast/cmd/display.c
Since GRASS4 did the colors right, using both GRASS4 and GRASS5
drivers, I suspect one of the Libraries and not the XDRIVER.
look at D_set_colors ().
At the moment I don't have time to track this "bug" down.
maybe in a few weeks, if you don't get to it first.
There is a development mail-list for GRASS it is
grass5 at baylor.edu.
This discussion may generate more help if conducted publicly
there.
( I am posting this response there )
C.
E-Mail: candrsn at mindspring.com
Date: Sun, 01:00:00 +0000 (GMT)
Flying Monkeys Usually Mean Trouble.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
