[GRASS5] Recent additions to CVS
Markus Neteler
neteler at geog.uni-hannover.de
Fri May 26 08:51:33 EDT 2000
Dear developers,
from the untested section of 4.x I have added some modules:
src/mapdev/
v.llabel - label all unlabeld vectors (see v.alabel)
v.rm.dangles - remove dangles
v.in.arc.poly - import ARC/INFO polys with closed polygons
v.out.mif - export MIF (working? Rich, for you?)
v.rmdup - remove duplicate vector lines # note: does not compile yet!
src/misc
m.in.ntf - module to read an Ordnance Survey NTF file
Except v.llabel they are not added to src/CMD/lists/GRASS yet.
Please tell me if they are compiling/working for you.
They might be useful for your work or developments.
Best regards
Markus
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
