[GRASS5] XDRIVER popup bug
Markus Neteler
neteler at geog.uni-hannover.de
Wed May 24 09:19:32 EDT 2000
On Tue, May 23, 2000 at 12:22:48AM -0400, Carl Anderson wrote:
> Markus,
> Here is a quick fix for the indicated problem
> I changed src/display/devices/XDRIVER/XDRIVER24/Panel.c
> so that if any part of the window was off screen during
> an image capture (popup, menu) the window is moved such that
> the entire window is on screen.
> try it using d.zoom
> put part of the window off screen to each side (top, bottom,..)
Carl,
it is working perfectly! Thanks, this will prevent many
users from problems.
> its stuff. I hope that moving from file/fifo's to sockets help that,
> so that nasty line can be dropped.
Did you find time to look for that? I am just interested
as the windows port (by John) requires such sockets.
Maybe he or someone else could assist?
Many thank for the bugfix,
best wishes
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
