[GRASS5] CVS administration
John Huddleston jhudd at itc.nrcs.usda.gov
Tue May 23 12:39:50 EDT 2000
No, the cvs update, watch, and edit commands do not
change permissions on the local directory.
Justin, chmod the directory to 777 locally.  If the
repository directory were read only, then you would
not have been able to checkout a file.  It needs to
do a temporary lock and lock directory for the
short period of time that you are accessing the file.
John Huddleston
----- Original Message -----
From: Markus Neteler <neteler at geog.uni-hannover.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Tuesday, May 23, 2000 6:47 AM
Subject: Re: [GRASS5] CVS administration
> On Tue, May 23, 2000 at 05:09:16PM +0000, Justin Hickey wrote:
> > Hello Bernhard
> > Did this include making some files like src/CMD/lists/GRASS read only?
We just
> > noticed this when we tried to change this file after we performed a cvs
update.
> > Is this part of your change or is this a feature of cvs update?
> Hi Justin,
> I have the same problem with this file (and a few others).
> Is it related to cvs watch or cvs edit (John, you will know it :-) )
> Thanks
>  Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
