[GRASS5] FreeBSD compile problems
Eduardo B. Fonseca ebf at cwb.fnn.net
Wed May 17 10:49:28 EDT 2000
oooopppsss....
I will download the CVS version...
thanks..
Eduardo.
On Wed, 17 May 2000, Markus Neteler wrote:
> Hi Eduardo,
> On Wed, May 17, 2000 at 11:30:39AM -0300, Eduardo B. Fonseca wrote:
> > Hello Guys,
> > I'm trying to compile Grass5 on a FreeBSD-3.4 system... Markus already
> > pointed me to the libncurses problem, but I'm still getting some compile
> > errors... check it out:
> > GISGEN: src/mapdev/v.autocorr - Wed May 17 11:25:26 EST 2000
> I fear you do not have the latest version... :-)
> > /3/gis/grass5.0beta/src/mapdev/v.autocorr
> >   mkdir OBJ.i386-unknown-freebsd3.4
> >   make -f OBJ.i386-unknown-freebsd3.4/make.rules
> > rm -f OBJ.i386-unknown-freebsd3.4/main.o
> > gcc -g -O2 -I/3/gis/grass5.0beta/src/libes/vect32/Vlib -I/3/gis/grass5.0beta/src /libes/vect32/diglib -I/3/gis/grass5.0beta/src/include  -c main.c
> > main.c: In function `main':
> > main.c:156: too many arguments to function `c_matrix'
> > *** Error code 1
> Edit line 156 (?)
> src/mapdev/v.autocorr/main.c:
> from
> n = c_matrix (&Map, &Plus, c);
> to
> n = c_matrix (&Map, &Plus);
> Then it compiles. Note that the GRASS/CVS version contains further
> fixes from David Gray.
> Cheers
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
