[GRASS5] Splitting GRASS 5 into stable and unstable
Markus Neteler
neteler at geog.uni-hannover.de
Tue May 9 13:14:53 EDT 2000
Hi developers,
thanks Eric for your comments. As being far away from a
CVS expert, I am very interested in comments!
It seems we have to judge if we the planned updates
are significant changes in structure or not.
What I expect to be updated soon is (I hope it will happen):
(1) better/new makefile support:
- auto-conf fully applied
- split GRASS into thematic modules which could be downloaded
and added to "GRASS-Core" on demand could be feasible
- using shared libs (*if* recommended)
- the make process should ignore missing modules to
support GRASS modularity (in case the user downloads only
part of the code)
(2) new XDRIVER2:
- layer technology
- socket support instead of fifos (to run faster and optionally
on Windows platforms)
(3) clusterGRASS:
- in case someone wants to improve/rewrite parts of
GRASS to allow parallel computing: is it an own
project or can it be done within the standard
package (checked by auto-conf)?
Eric, as you are working on "auto-conf" support: Does it require significant
structural changes or not? In case we apply your patches directly, do we get
it stable soon (say: one or two month)? Is a new internal structure required
or updates only?
Concerning the proposed GRASS modularity:
I guess some of you know "R": They provide so-called third party
extensions which can be easily included. The local documents are
updated automatically with all cross references etc. It is quite
nice: http://cran.at.r-project.org/
http://cran.at.r-project.org/src/contrib/PACKAGES.html
This is more the bazaar type than cathedral... (well, this discussion
is another topic).
The short history of GRASS 5 was mainly updating, bugfixing and
prototyping. Now it will be time to go for above changes.
To conclude: In case we can apply above improvements, to you
think we have significant changes? If not, we may not need
a new parallel version and/or branches.
Hoping for further comments
Markus Neteler
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 3117
max: 0
