[GRASS5] DBMI-ODBC
John Huddleston jhuddles at rocky.itc.nrcs.usda.gov
Tue May 2 10:30:47 EDT 2000
Markus,
FYI, I have successfully built unixODBC-1.8.7
for Windows NT using the Cygnus Toolset B20.1
John Huddleston
----- Original Message -----
To: <grass5 at geog.uni-hannover.de>
Sent: Tuesday, May 02, 2000 6:43 AM
Subject: [GRASS5] DBMI-ODBC
> Hi,
> (sorry if you received this twice, Markus Neteler recommended me to send
it here too)
> I work on ODBC (http://www.unixodbc.org/) driver for DBMI (src/libes/dbmi)
> + some modules based on DBMI.
> Work is not finished but most of old modules (src/libes/dbmi/clients) and
new
> v.db.reclass run.
> I want discuss following list of changes before commiting to CVS:
> - add to src/include/dbmi.h structures:
>   typedef struct _db_connection
>       char *driverName;
>       char *databaseName;
>       char *location;
>       char *user;
>       char *password;
>       char *keycol;        // name of default key column
>   }dbConnection;
>   typedef struct
>       int  count;     // number of defined rules
>       int  alloc;     // size of allocated array
>       char *table;    // table name
>       char *key;      // key column name
>       int  *cat;      // array of new category numbers
>       char **where;   // array of SQL WHERE conditions
>       char **label;   // array of new category labels
>   }dbRclsRule;
> - add to DBMILIB functions:
>   int   db_set_connection        (dbConnection *connection );
>   int   db_get_connection        (dbConnection *connection );
>   void        db_rcls_rule_extend       (dbRclsRule *rule , int n );
>   dbRclsRule * db_rcls_rule_init        (int n );
>   int         db_rcls                   (dbRclsRule *rule , CatValI
**new );
> - add to /src/libes/dbmi/lib/start.c reading from dbConnection if driver
>   was not specified
> - modify command parameters in src/libes/dbmi/clients modules
>   to not required if defined in dbConnection (use default)
> - change in src/libes/dbmi/clients/Gmakefile:
>   HOME=$(GISBASE)/etc/dbmi/bin
>   to
>   HOME=$(GISBASE)/etc/bin/main/cmd
>   and remove
>   if [ ! -d $(GISBASE)/etc/dbmi ]; then mkdir $(GISBASE)/etc/dbmi; fi; \
>   if [ ! -d $(HOME) ]; then mkdir $(HOME); fi;
> - add src/libes/dbmi/drivers/odbc - ODBC driver
> - add src/libes/dbmi/clients/db.connect - similar as g.select.pg but
>   module name db.select is already used, problem: password is saved
>   in file
> - add src/mapdev/v.db.reclass
> - add to VECTLIB_REAL functions for reclassification - may be used in
future also
>   by v.reclass (I am not satisfied with creating reclass file and running
> v.reclass
>   from DB reclass modules):
>   int V_rcls_line (char *in_name, char *out_name, CatValI *new, int ncat,
int
> append);
>   int V_rcls_area (char *in_name, char *out_name, CatValI *new, int ncat,
int
> append, int dissolve);
> - add to src/include/gis.h structures for storing values for cats
>   ( new category value, number of elements in cat, area, length, x,y, ...)
>   typedef struct
>       int  min,max;  // array range
>       int  *val;  // array of integers
>   }CatValI;
>   typedef struct
>       double *val;  // array of doubles
>   }CatValD;
> - add to GISLIB functions:
>   CatValI *G_catvali_init( int min, int max);
>   void G_catvali_extend( CatValI *, int max);
> Radim
> If you want to unsubscribe from GRASS Development
> Team internal mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
> length: 3835
> max: 0
length: 5084
max: 0
