[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/libes/raster
Andreas Lange
Andreas.Lange at Rhein-Main.de
Thu Nov 30 19:06:02 EST 2000
Hi Eric, Hi Markus,
very nice, it works now. Now you can even close monitors by "killing"
them.
I have the fix for the typecast ready and i have nearly ready a code
reorganization that allows to switch between fifo and ipc messages by
compiler switch (-DIPC or -DFIFO).
Just to announce this, so that we do not get under our feet again. I
hope that it can wait until Saturday morning, as i will check it in
then.
I'll have a look at this weird CELL driver problem too.
There is no need to propagate the change to the ipc-new/io.c, as it
works with ipc msgs. because the system with testing by opening a fifo
is not used there.
cu,
Andreas
Markus Neteler wrote:
> Hi Eric,
> On Thu, Nov 30, 2000 at 04:47:06AM +0100, grass at intevation.de wrote:
> > Date: Thursday November 30, 2000 @ 3:47
> > Author: eric
> > Update of /grassrepository/grass/src/libes/raster
> > In directory intevation.de:/tmp/cvs-serv4834
> > Modified Files:
> > io.c
> > Log Message:
> > Fix d.mon -L bug I think (this'll need to be propagated to io.c in ipc.new)
> congrats! It is fixed for Linux/fifos.
> Regards
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
