[GRASS5] XDRIVER compile problem on CRAY
Andreas Lange
Andreas.Lange at Rhein-Main.de
Thu Nov 30 13:09:05 EST 2000
Hi Markus,
i see what the problem is. The typecasts are incorrect. Sorry.
But please allow me until Saturday to make the fixes, as i am busy right
now and want to test again (with lclint/gcc -ansi -pedantic) before
committing.
The last round of updating these files was a bit chaotic and i have to
merge some Cygwin related changes too.
cu,
Andreas
Markus Neteler wrote:
> Hi all,
> maybe Andreas can help: A new compile problem is there on CRAY,
> probably due to the latest cast fixes (I won't change anything here :-)
> /home/t3e/fsn/nhdc/nhdcmark/grass/src/display/devices/XDRIVER/XDRIVER24
> make -f OBJ.alpha-cray-unicosmk2.0.4.X/make.rules
> cc -g -I../../lib
> -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include -c Raster.c -o
> OBJ.alpha-cray-unicosmk2.0.4.X/Raster.o
> CC-513 cc: ERROR File = Raster.c, Line = 83
> A value of type "XImage *" cannot be assigned to an entity of type "char
> grimage->data = (XImage *) G_malloc((size_t) (num *
> bytes_per_pixel));
> CC-513 cc: ERROR File = Raster.c, Line = 85
> grimage->data = (XImage *) realloc((void *)grimage->data,
> (size_t) (num * bytes_per_pixel));
> CC-167 cc: WARNING File = Raster.c, Line = 94
> Argument of type "unsigned int *" is incompatible with parameter of type
> "int *".
> _get_color_index_array(array, num) ;
> 2 errors detected in the compilation of "Raster.c".
> Make: "cc -g -I../../lib -I/home/t3e/fsn/nhdc/nhdcmark/grass/src/include
> -c Raster.c -o OBJ.alpha-cray-unicosmk2.0.4.X/Raster.o": Error code 1
> cmd-2436 make: Stop.
> Make: "/home/t3e/fsn/nhdc/nhdcmark/grass5bin/gmake5 XDRIVER24": Error code 1
> Especially line 83/85 are causing an error on CRAY, but they cause a warning
> on Linux as well.
> Could anyone take care for this?
> Thanks
> Markus
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
