[GRASS5] Re: compile errors on Linux
Markus Neteler
neteler at geog.uni-hannover.de
Thu Nov 30 12:16:09 EST 2000
On Thu, Nov 30, 2000 at 08:27:29AM -0800, Eric G . Miller wrote:
> On Thu, Nov 30, 2000 at 05:00:39PM +0000, Markus Neteler wrote:
> > Yesterday I have updated "configure.in" not to stop. Obviously
> > Eric has reverted this change.
> > I agree not to make opengl mandatory to run grass and to modify
> > the AC_MSG_ERROR to AC_MSG_WARN related to opengl. Otherwise we
> > will receive many mails from struggling users.
> > As > 90% of GRASS don't depend on openGL, there is no need to make
> > the configure stop if openGL is not found.
> > Until this is hopefully changed, you can use
> > configure --enable-opengl=no
> Sorry Markus, I did a lot of changes before doing an update, I thought I
> got that one set to AC_MSG_WARN before I committed it (you can change
> again if you like, I can't touch it for 8 or so hours, off to work....).
Eric,
fine - I thought you would be against this change. But when looking at
it again I am not fully sure if it isn't already changed. Perhaps Huidae
missed another cvs update?
I will check it - happy working!
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
