[GRASS5] Re: compile errors on Linux
Eric G . Miller egm2 at jps.net
Thu Nov 30 11:27:29 EST 2000
On Thu, Nov 30, 2000 at 05:00:39PM +0000, Markus Neteler wrote:
> Yesterday I have updated "configure.in" not to stop. Obviously
> Eric has reverted this change.
> I agree not to make opengl mandatory to run grass and to modify
> the AC_MSG_ERROR to AC_MSG_WARN related to opengl. Otherwise we
> will receive many mails from struggling users.
> As > 90% of GRASS don't depend on openGL, there is no need to make
> the configure stop if openGL is not found.
> Until this is hopefully changed, you can use
> configure --enable-opengl=no
Sorry Markus, I did a lot of changes before doing an update, I thought I
got that one set to AC_MSG_WARN before I committed it (you can change
again if you like, I can't touch it for 8 or so hours, off to work....).
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
