[GRASS5] New initialization code
Eric G . Miller
egm2 at jps.net
Thu Nov 30 10:35:05 EST 2000
On Thu, Nov 30, 2000 at 04:03:18PM +0700, Justin Hickey wrote:
> Hi Robert
> Robert Lagacé wrote:
> > We need to know that, on all SVR4 systems such as HP-UX 10 and 11, all
> > non OS software should be installed under /opt/. So, Grass would be
> > in /opt/grass/bin/ and appropriate directories under /opt/grass/.
> > System admin is simplified because everything is under one directory.
> > I will test the new configure under HP-UX when I will have time (in
> > two weeks).
> Hmm. Another "standard" local program install directory. Arrrgh. Well,
> the only thing I can think of is that we use some way in configure.in to
> detect HP-UX. What is the output of "uname -s" for HP's? If we can't get
> it installed in /opt by default, then you will have to use the --prefix
> and --bindir options for configure.
> By the way, what is the bin directory that appears in user's PATH's,
> /opt/bin/?
> Thanks in advance for the test!!
I'd advocate against worrying about this. This is what the --prefix=
directive to configure is for. Same with --bindir.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
