[GRASS5] Re: compile errors on Linux
GRASS grass at geni.knu.ac.kr
Thu Nov 30 10:04:47 EST 2000
From: Markus Neteler <neteler at geog.uni-hannover.de>
> On Thu, Nov 30, 2000 at 11:11:48PM +0900, GRASS wrote:
> > Hi developers,
> > I've experienced compilation errors in src/libes/vask and src/libes/gis
> > directories on Linux.
> > I succeeded to compile two modules by adding -DHAVE_TERMIO_H into
> > src/libes/vask/Gmakefile and -DSETPGRP_VOID -DHAVE_TERMIO_H into
> > src/libes/gis/Gmakefile.
> > Where should two macros be defined? I have no clue and my life OS isn't linux
> > Please fix these bugs.
> Hi Cho,
> this is defined in
> src/include/config.h
> neteler at bermuda:~/ggg > grep HAVE_TERMIO src/include/config.h
> #define HAVE_TERMIO_H 1
> #define HAVE_TERMIOS_H 1
> neteler at bermuda:~/ggg > grep SETPGRP_VOID src/include/config.h
> #define SETPGRP_VOID 1
> So the including of "config.h" is required. Please add in the files
> where the error occurs. From "SUBMITTING" (added by Justin this morning):
> "5.  To ensure that the software system continues to work, please include
>         #include "config.h"
>     in your files and make use of the various system dependencies
>     contained therein.  As one example of this, see
>     src/paint/Interface/driverlib/io.c.  Please refrain from declaring
>     system functions within the software; include the proper header files
>     (conditionally dependent on config.h macros if necessary) instead.
> As you can find out the files affected, may I ask you to add the statement?
Oops! Sorry for that.
configure just exited because opengl was not found. I think that opengl is not
mandatory to run grass. config.h was not generated properly, so my errors
occurred.
What about you?
Regards,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
