[GRASS5] New initialization code
Robert Lagacé
lagace at echo.grr.ulaval.ca
Thu Nov 30 10:29:16 EST 2000
Justin Hickey wrote:
> Hi Robert
> Robert Lagacé wrote:
> > We need to know that, on all SVR4 systems such as HP-UX 10 and 11, all
> > non OS software should be installed under /opt/. So, Grass would be
> > in /opt/grass/bin/ and appropriate directories under /opt/grass/.
> > System admin is simplified because everything is under one directory.
> > I will test the new configure under HP-UX when I will have time (in
> > two weeks).
> Hmm. Another "standard" local program install directory. Arrrgh. Well,
> the only thing I can think of is that we use some way in configure.in to
> detect HP-UX. What is the output of "uname -s" for HP's? If we can't get
> it installed in /opt by default, then you will have to use the --prefix
> and --bindir options for configure.
The output of uname -s is HP-UX.
I think that the last version of Solaris use this standard also and all
SVR4 compliant OS.
> By the way, what is the bin directory that appears in user's PATH's,
> /opt/bin/?
With a well configure application, the /opt/application/bin directory is
added to the user search path. This solve a lot of admin problems.
> Thanks in advance for the test!!
> PS Cheers to a fellow Canadian! :)
> Sincerely,
> Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
> High Performance Computing Center
> National Electronics and Computer Technology Center (NECTEC)
> Bangkok, Thailand
> People who think they know everything are very irritating to those
> of us who do. ---Anonymous
> Jazz and Trek Rule!!!
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
