[GRASS5] MATHLIB not found link error
Markus Neteler
neteler at geog.uni-hannover.de
Wed Nov 29 06:45:47 EST 2000
On Wed, Nov 29, 2000 at 06:54:13AM -0500, Tim Cera wrote:
> With the CVS checkout on Tuesday night, './configure', 'make install',
> received an error for just about every link. "Cannot find @MATHLIB@
> .." or something to that effect. The command line shows @MATHLIB@
> instead of "-lm", or whatever my distribution needs. Suse 6.4. Sorry
> that I don't have time to track down solution.
Hi Tim, hi Fernando,
this was reported for several platforms. It would be a help
if you could copy-paste this part of configure messages:
checking for xdrmem_create in -lsun... (cached) no
checking for xdrmem_create in -lnsl... (cached) yes
checking for xdrmem_create in -lc... (cached) yes
checking for deflate in -lz... (cached) yes
checking for atan in -lc... (cached) no
checking for atan in -lm... (cached) yes
The last two might cause the problem as the MATHLIB is not unset
properly. So we need to know about your configure output.
Thanks
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
