[GRASS5] New initialization code
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 23:44:06 EST 2000
Hi Markus
Markus Neteler wrote:
> > If the problem is that $(UNIX_BIN) is being defined as the same as
> > $GISBASE, then the problem is in configure, not the Gmakefile. If we
> > can't get a reasonable default for bindir in configure (either
> > /usr/local/bin - what it should be or /usr/bin - I disagree with
> > this but if that's the only way ok) then we will have to tell users
> > to use the --with-bindir option to configure.
> Hi Justin,
> I don't fully get what you dislike, is it that I prefer "grass5" to
> be stored outside of $GISBASE?
> From the Linux view I would prefer this way:
> The average linux user who has a compile should be able to run:
> configure # without annoying extra parameters
> make install
> grass5
> This startup script should go somewhere here:
> echo $PATH
> /home/neteler/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:/usr/games/bin:/usr/games:/opt/gnome/bin:/opt/kde/bin:/usr/openwin/bin:.
> If you would have to copy it manually from $GISBASE/bin to
> /usr/[local/]bin,
> that's extra work... Perhaps you think the same?!
Yes we are thinking the same, I agree that grass5 should be in the path.
Perhaps the confusion is on my part. I was under the impression that you
thought that since grass5 is put into $GISBASE/bin by default that it
was a problem with the initialization script placing the grass5 script
in that directory. I'm sorry if this was the case. It is actually a
configure problem because in configure, the bindir was not defined
properly and was defaulting to /usr/local/grass5/bin thus the
$(UNIX_BIN) variable in the src/general/init/Gmakefile becomes
/usr/local/grass5/bin. My fix I found yesterday, (and will be committed
soon) solves this problem.
My disagreement with /usr/bin comes from system administration. Software
(or executables) should not be installed under /usr/bin since it
contains vendor supplied programs. The only changes I make under
/usr/bin is to create links to executables that replace programs in
/usr/bin. For example, I install the latest Tcl/Tk under /usr/local. I
need to create a link /usr/bin/wish so that scripts that begin with
#!/usr/bin/wish
will use the new wish command. Anyway, all non-vendor installed software
should go under /usr/local/bin not /usr/bin. At least that was what I
was taught about system administration.
Are we still not understanding each other? :)
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
