[GRASS5] configure.in Wants testers...
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 23:17:16 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> On Tue, Nov 28, 2000 at 04:26:38PM +0700, Justin Hickey wrote:
> Well here's my understanding:
> foo=${bar} # Perform variable expansion on "bar", put result in foo.
> foo=$(bar) # Execute "bar" in a subshell, put result in foo.
> The $(cmd) syntax is supposed to be the portable equivalent of `cmd`,
> only special characters $ \ and * (I think) are not treated as
> "metacharacters".
> This $(...) syntax is different from Makefile $(...) which apparently
> is variable substitution/expansion.
Ahh, OK, I went looking into why this doesn't seem to work for SGI and
found on the man page for sh the following:
Command Substitution
The standard output from a command enclosed in parentheses preceded by a
dollar sign ( $() ) or a pair of grave accents (``) may be used as part
or all of a word; trailing newlines are removed.
Obviously it is supposed to work on SGI's, they even claim the (``)
style to be archaic. However the following script
#!/bin/sh
qwer=$(pwd)
asdf=`pwd`
echo $qwer
echo $asdf
Produces the following output
$(pwd)
/usr/people/jhickey/testDir/sh
Thus, it obviously does not work on SGI as it is supposed to. I am due
for an OS upgrade soon, so if this problem is not solved with the
upgrade, I will try to submit a bug report to SGI.
In the meantime, would it be safe to change the SRCDIR code in
configure.in to `pwd` instead of $(pwd)? Perhaps we can add a comment to
change it back to $(pwd) when SGI fixes this bug. Just an idea.
BTW, do you want me to submit the bindir change or do you want to? I
didn't change it yesterday because I didn't have time to test --bindir
and --with-bindir. I tested them today and --bindir seems to work, but
--with-bindir does not, but then I can't find --with-bindir in the
configure.in file. Please let me know what you want to do.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
