[GRASS5] New initialization code
Justin Hickey
jhickey at hpcc.nectec.or.th
Tue Nov 28 04:05:59 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> Starting GRASS ...
> Error in startup script: couldn't read file "wish8.2": no such file or
> directory
> /usr/local/grass5/etc/Init.sh: [: ==: unary operator expected
> /usr/local/grass5/etc/Init.sh: GISDBASE: parameter null or not set
> But the problem stems from the finding of the "wish" command. On my
> system I have "wish", "wish8.0", "wish8.2" and "wish8.3". "wish" is a
> symbolic link the eventually points back to "wish8.3" (as the
> preferential "wish"). The others are there because some programs are
> built against older versions of Tcl/Tk. There *might* be a fairly
> straightforward solution for this. In the configure.in, I grep tcl.h
> or tk.h for the '#define TK_VERSION "x.x"' string. I use this to
> attempt linking/validation of libraries. This information could
> easily be passed down the Makefile chain and *should* obviate the need
> to search for a particular "wish". Perhaps this would be a problem
> for a binary compilation using one version of tcl/tk and a user who
> has a different version. Anyway, I could easily export that variable
> if it will help. Though, I wonder if it wouldn't be safer just to try
> "wish"?
Thanks for the report Eric. Markus, this is more your area than mine.
Any idea for fixing this?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
