[GRASS5] r.proj, v.proj, s.proj: parameter consistency fixed
Markus Neteler neteler at geog.uni-hannover.de
Mon Nov 27 05:52:59 EST 2000
Hi all,
the parameter consistency is fixed now:
r.proj help
Description:
 re-project a raster map from one location to the current location
Usage:
 r.proj input=name location=name [mapset=name] [dbase=name]
   [output=name] [method=name] [resolution=value]
Parameters:
       input   input raster map
    location   location of input map
      mapset   mapset of input map
       dbase   path to GRASS database of input location
      output   output raster map
      method   interpolation method to use
               options: nearest,bilinear,cubic
               default: nearest
  resolution   resolution of output map
v.proj help
Usage:
 v.proj input=name location=name [dbase=name] [mapset=name]
   [output=name]
Parameters:
     input   input vector map
  location   location containing input vector map
    mapset   mapset containing input vector map
    output   output vector map
s.proj help
Description:
 Allows the user to re-project a sites file from one location to the current
location.
Usage:
 s.proj input=name location=name [dbase=name] [mapset=name]
   [output=name]
Parameters:
     input   input sites list
  location   location of input sites list
    mapset   mapset of input sites list
    output   output sites list
The documentation is changed accordingly.
Please note: You don't have to specify the *full* parameter(s),
just the first letter(s) are enough to make GRASS guess which parameter is
used. Example:
  r.proj i=dgm1km l=europa ma=europa me=cubic
is sufficient to distinguish MEthods and MApset.
You may note that we are currently adding more information to "help"
parameter: A new "Description" field is there to explain the purpose of
the module.
Kind regards
 Markus Neteler
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
