[GRASS5] How to manage versions of perl and wish?
Markus Neteler
neteler at geog.uni-hannover.de
Mon Nov 27 05:01:50 EST 2000
Hi all,
currently we are facing two problems with version dependencies
and/or paths for scripts:
- perl: how to manage the different paths?
Proposals:
- write a *general* wrapper searching the perl location on startup
- store it in GRASS environment and expand on script startup
#! $(PERL)
(is this portable?)
Affected modules:
- g.html2man
- others?
- wish: unfortunately the version number is coded into wish. At least
we have to check if only wish4.2 is installed (unsupported).
Proposals:
- write a *general* wrapper searching the wish name and location on
startup (I have tried that for tcltkgrass, see bin/tcltkgrass)
(is this portable?)
Affected modules:
- tcltkgrass
- nviz
- d.dm
- others?
We need an agreement here. The version numbers shouldn't be hardcoded into
the modules itself.
Regards
Markus
PS: Just facing the problem:
d.dm
/usr/local/grass5/scripts/d.dm: exec: wish8.0: not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
