[GRASS5] Win32 compile with cygnus ...
John Huddleston
jhudd at lamar.colostate.edu
Sat Nov 25 09:10:41 EST 2000
Hi Andreas,
----- Original Message -----
From: "Andreas Lange" <Andreas.Lange at Rhein-Main.de>
To: <grass5 at geog.uni-hannover.de>
Sent: Friday, November 24, 2000 10:32 AM
Subject: Re: [GRASS5] Win32 compile with cygnus ...
> Hi John, Hi Markus, Hi Grasslist,
> i finished a compile with the latest cygwin setup on NT 4.0 SP 5 in this
> minute.
> I can now compile all modules from the standard GRASS list file
> (including r.in.png and r.out.png).
> I'll check in my changes to the CVS in the next days. I'll check in my
> head file too.
> I have now a running X11R6.4 installation, but can not start grass5 in
> the xterm. But i managed somehow to start xwin from the grass shell
> prompt.
I have been using Starnet X-win http://www.starnet.com/ for some time
now. Using it with the X11R6.4 libes has allowed me to compile my X11
code. They have a trial version which runs for two hours. See the lycos
http://ftpsearch.lycos.com/ and search for xwin41.
> _But_ the problem still remains that there is no graphical output yet.
> After some code modifications i can now even compile the new IPC message
> queue setup, but this still requires a lot of work to be done.
Do you want me to add the cygipc code to the grass5 cvs? Markus?
> I would vote for dropping support for Windows 95/98 because the new
> X11R6.4 port for windows with the cygnus tools will not work with Win9x.
> The X11 programs are linked dynamically to the X11R6 libraries, so that
> there is no chance to get this to work with the commercial X Servers
> (e.g. MI/X), as they are based on X11R5. The usage of the X11 port for
> the B20 version of the cygnus tools under the current V1.1 is not
> supported.
Yes, I migrated to Win2000 for that reason; plus, both NT and 2000 have
better support for display. I have not tried windows ME with it, perhaps
that is one upgrade path for 98 users. I still would recommend Win2000.
> >From my initial testing i can say that there are waiting some nasty
> surprises, so that i would not recommend the download of the GRASS
> binaries for cygwin to people who are not of the adventurous nature. And
> the missing graphical output (the CELL and HTMLMAP driver depend on the
> missing fifos!) and the mangled bash setup makes it a pain to work with.
> Just as a warning, so that no false expectations arise.
> How can we get graphical output and tcltkgrass running under this setup?
> I can still not say if i can get the X monitor to work and if tcltkgrass
> will work under the X11 Window Setup. I have the initial impression that
> the X11 Setup is not for real work (it is a beta!).
This is one of those cases, where if we had money to travel, I would say
let's get together for two to three days and make it work.
John Huddleston
> If someone has ideas how we can get a windows port with graphical
> output, please tell!
> cu,
> Andreas
> John Huddleston wrote:
> > Markus (Grass list)
> > I updated my cygwin to the latest, completely removed all grass
> > code from my drive, checked out grass5, and rebuilt grass5
> > with only one hitch. The src/cmd/head file still is not right.
> > More details later, I uploaded the binary tar.gz to the incoming
> > directory.
> > http://www.geog.uni-hannover.de/grass/grass5/binary/windows_cygnus/
> > I see the email about the w98. Clearly, the cygwin code has
> > disclaimers about using it under Windows 98. I used B20.1
> > of Cygwin when I used w98. All the grass5 compiled nicely
> > with it. The B20.1 uses the cygwin32 convention though, and
> > the config.guess must be adapted to ensure
> > For those who have NT or Win2000, the install of Cygwin is
> > more robust than ever, does not conflict with Windows, allows
> > a Unix environment for windows users. See the URL
> > http://sources.redhat.com/cygwin/ and download the setup.exe
> > Execute it from windows explorer or the CMD line, not
> > from bash. click Next-> first.
> > Next, it will prompt you to
> > o) download from the internet
> > o) install from internet
> > o) install from local
> > If you want the binaries (and sources) local, click the first
> > If you have limited space, click the second
> > If you have already downloaded from the internet, do the third
> > I download from the internet to my F: drive first
> > and then run setup a second time and install on
> > either my C: or D: drive. The default is the C:\cygwin
> > which makes the root "/" equal to C:\cygwin. I personally
> > do not like that since I cannot get at my C: files from /
> > so I override it with "C:\". It warns me but goes
> > on.
> > Finally, the best part is that all the tcl/tk, png,tiff,
> > and other items required to build grass5 are included
> > with one exception, the libcygipc.a archive.
> > So, I am attaching the head file for your use. Some
> > changes are yacc to bison -y, adding -lcygipc after
> > XDRLIB. Rename cygwin.txt to the head file as
> > head.i686-pc-cygwin
> > Let me know if you need more assistance,
> > John Huddleston
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
