[GRASS5] Win32 compile with cygnus ...
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Nov 23 16:53:42 EST 2000
Hi Mike,
i don't dare to say, but for my first try with cygnus on Win i used an
old computer with Win 95 installed. I exported my local copy of the CVS
tree with samba from a linux machine and mounted it within the cygnus
shell. The multi-OS build of GRASS from a single directory tree works
really.
Now that i know that it generally works i use NT 4.0 SP5 on a computer
with 128 MB RAM. I think that Win 9x is generally not stable enough for
serious work. And i see no chance to get the X11 thing working on Win
9x.
cu,
Andreas
Mike Thomas wrote:
> Hi guys.
> I found the problem.  I swapped the Cygwin sh.exe (by default they use
> ash.exe) to bash.exe and the problem went away.
> Unfortunately the entire OS crashes not long after starting now!
> I'm using Win 98 with 64M of RAM and a spare gig of disk to build.
> Are you using NT4, NT2000 or W98?  My experience is that Cygwin is usually
> more stable under NT.
> > But i can not confirm this a cygwin bug.
> > With my cygwin setup (last updated one week ago) ./configure, make, make
> > install and gmake5 work.
> I've been updating regularly over that period and got the same problem all
> the time.
> > So you could try the following: update cygwin, do a make distclean and
> > ./configure && make && make install again. And/or do a cvs update -dP
> > before starting the new build.
> I have been using a completely fresh cvs copy each time.
> Cheers
> Mike Thomas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
