[GRASS5] MacOS X binaries dependencies
Jeshua Lacock jeshua at SierraMaps.com
Thu Nov 23 16:42:46 EST 2000
>On Thu, Nov 23, 2000 at 01:33:37PM -0800, Jeshua Lacock wrote:
>>  >On Thu, Nov 23, 2000 at 02:21:49AM -0800, Jeshua Lacock wrote:
>>  >>  >  > I made a symbolic link  /usr/local/grass-5.0b  ->
>>/usr/local/grass5
>>  >>  >>  and it works!!
>>  >>  >>  (Markus: can you please add this to the installation instructions?:
>>  >>  >>  cd /usr/local; ln -s grass-5.0b grass5;)
>>  >>  >Actually, we need to find where the grass-5.0b is coming
>>from. We made a
>>  >>  >decision that it would be grassx where x is the current major version
>>  >>  >number to simplify coding and decrease user confusion.
>>  >>  Yes, however since nearly 2000 people have download the OS X
>>  >>  binaries, I think it would be useful to add the symbolic link to the
>>  >>  instructions until beta 9 is posted.
>>  >Jeshua,
>>  >actually I don't understand the problem. We have a grass5b8_mac package
>>  >and a grass5install.sh script. The script takes care where to install
>>  >the package and generates the startup script depending on the install
>>  >path. This works since month.
>>  >Why this confusion? :-)
>>  Markus,
>>  That's all right, I don't understand either!!  ;-D
>>  All I know it that the GUI will not work unless this symbolic link is
>>  created....
>Could you do me the favor, remove the link and send the error
>message? Then we might fix it (if something has to be fixed).
Markus,
d.mon says:
Sorry, </usr/local/grass-5.0b/dev/fifo.1a> not available
Have GRASS administrator check etc/monitorcap file
And I get this error because grass is installed at/usr/local/grass5/...
Yours,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
