[GRASS5] New MacOS X compilation errors
Justin Hickey jhickey at hpcc.nectec.or.th
Tue Nov 21 22:28:58 EST 2000
Hi Andreas and all
Andreas Lange wrote:
> Generally the use of G_malloc is preferred over malloc.
> _BUT_ in this case i feel that it is unneccessary to use G_malloc, as
> the code is stable, no debugging is needed etc. And G_malloc will give
> a (slight) overhead due to one function call more.
Hmmm. I think we should be consistent with things like this. Either we
always use G_malloc or we never do. Otherwise we get code like we now
have in grass with some people using G_malloc and others using malloc.
The problem is those using malloc are not always checking if memory was
allocated properly. This is the reason to use G_malloc - to ensure that
the memory was allocated properly.
As for the function call overhead, it is minimal with today's machines
and if I recall correctly, I think I read somewhere that memory
allocation is an expensive operation. Thus, the cost of memory
allocation should outweigh the cost of function call overhead.
I suggest that we should always use G_malloc (and the other allocation
functions - G_calloc etc.) unless it can be shown that using malloc
(with the appropriate check for errors) produces a significant increase
in performance for a particular program. Personally, I don't think that
will happen, but that's just my opinion. We should keep in mind that
consistency is a crucial requirement for robust code.
Anyway that's just my 2 cents worth.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
