[GRASS5] New MacOS X compilation errors
Markus Neteler
neteler at geog.uni-hannover.de
Tue Nov 21 15:51:20 EST 2000
On Tue, Nov 21, 2000 at 08:55:13PM +0100, Andreas Lange wrote:
> Hi Markus,
> sorry if i was not clear.
> Generally the use of G_malloc is preferred over malloc.
> _BUT_ in this case i feel that it is unneccessary to use G_malloc, as
> the code is stable, no debugging is needed etc. And G_malloc will give a
> (slight) overhead due to one function call more.
> I yesterday checked in pedantic casts, changed all malloc/realloc
> function parameters to (size_t) casts and removed the problematic
> redefinition of char *malloc(); char * realloc(); that caused the
> problem with Mac OS X.
. mhhh - Now I have updated all this stuff. Shall I revert (I hope not)?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
