[GRASS5] New MacOS X compilation errors
Andreas Lange Andreas.Lange at Rhein-Main.de
Tue Nov 21 14:55:13 EST 2000
Hi Markus,
sorry if i was not clear.
Generally the use of G_malloc is preferred over malloc.
_BUT_ in this case i feel that it is unneccessary to use G_malloc, as
the code is stable, no debugging is needed etc. And G_malloc will give a
(slight) overhead due to one function call more.
I yesterday checked in pedantic casts, changed all malloc/realloc
function parameters to (size_t) casts and removed the problematic
redefinition of char *malloc(); char * realloc(); that caused the
problem with Mac OS X.
It _should_ compile on Mac OS X now, but this could only be proved by
Jeshua.
cu,
Andreas
Markus Neteler wrote:
> On Tue, Nov 21, 2000 at 07:59:32PM +0000, Markus Neteler wrote:
> > Hi Jeshua and all,
> > I have updated all malloc -> G_malloc in
> > src/display/devices/XDRIVER
> > cvs up src/display/devices/XDRIVER
> > gmake5 src/display/devices/XDRIVER
> > Please tell me if it is o.k. now.
> Hi all,
> do we have to change
> realloc
> as well?
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
