[GRASS5] MacOS X tcltkgrass errors <CVS>
Markus Neteler neteler at geog.uni-hannover.de
Tue Nov 21 13:43:01 EST 2000
On Tue, Nov 21, 2000 at 02:33:53PM +0700, Justin Hickey wrote:
> Hi Jeshua
> Jeshua Lacock wrote:
> > GRASS 5.0beta9 > /usr/local/grass-5.0b/bin/tcltkgrass: cd: no such
> > file or directory: /var/root/bin/powerpc-apple-macos [20]
> > /usr/local/grass-5.0b/bin/tcltkgrass: cd: no such file or directory:
> > /var/root/bin [20]
> > /usr/local/sbin [20]
> > Suggestions?
> What is happening here is that the tcltkgrass script is searching your
> $PATH variable for Tk "wish" commands. In this case there are 3
> directories defined in your path that do not exist on the system:
> /var/root/bin
> /usr/local/sbin
> I don't think any harm is done, Grass still starts doesn't it? But if
> you want to get rid of these messages, either create these directories
> on your system, or remove them from your PATH variable.
Hi Jeshua and Justin,
just checked in a fix to make "cd" quiet. Please test and
report...
cvs up src/tcltkgrass
cd src/tcltkgrass; gmake5
Hope this helps
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
