[GRASS5] Re: bug in configure routine
grass at geni.knu.ac.kr
Tue Nov 21 11:37:01 EST 2000
Subject: Re: [GRASS5] Re: bug in configure routine
> > Hmm, yes you're right. You can use --with-bindir instead of --bindir.
> Yes, I have done that to compile GRASS :-)
> > $bindir, created by --bindir, is not used though defined.
> > $BINDIR, created by --with-bindir, is used instead.
> > So i suggest to remove --bindir and other unused options of configure.
> > Any objection?
> The configure environment should just behave in a general way
> (as it is widely used) and be consistent.
> Jan
OK, however, those options do not work right now.
If we want to be consistent, those options should be fixed to work correctly.
In this case, what should be used if --bindir and --with-bindir both given?
Also, not a big deal. :-)
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
