[GRASS5] Re: bug in configure routine
GRASS grass at geni.knu.ac.kr
Tue Nov 21 09:15:10 EST 2000
Subject: [GRASS5] bug in configure routine
> Hi,
> I just experienced a small bug in the configure routine:
> [jan at mimirs grass]$ ./configure --help
> Directory and file names:
>   --prefix=PREFIX         install architecture-independent files in PREFIX
>                           [/usr/local/grass-5.0b]
>   --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
>                           [same as prefix]
>   --bindir=DIR            user executables in DIR [EPREFIX/bin]
> but AC_BINDIR_DEFAULT is /usr/local/bin and keeps this default
> no matter what I specifiy for prefix.
> Not a big deal, but should be straightened somehow.
> Cheers
> 	Jan
Hmm, yes you're right. You can use --with-bindir instead of --bindir.
$bindir, created by --bindir, is not used though defined.
$BINDIR, created by --with-bindir, is used instead.
So i suggest to remove --bindir and other unused options of configure.
Any objection?
Regards,
Huidae Cho
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
