[GRASS5] New MacOS X compilation errors
Jeshua Lacock jeshua at SierraMaps.com
Tue Nov 21 02:05:35 EST 2000
Andreas Wrote:
> Hi Markus, Hi Jeshua,
> generally all modules should use the available G_* functions instead of
> the system functions. I already changed some calls in some libraries and
> modules.
> Other functions than G_malloc are:
> G_strcasecmp
> G_strcmp
> etc, etc. (can prepare a list if there is interest).
> But in this special case i would recommend not to change this.
> The problem in SWITCHER.c is that the function calls are in pre-ANSI
> form without the proper typecasts and size_t types.
> Please give me some time to fix this!
Howdy Andreas, Markus and all.
Is there a temporary fix?  Maybe as Markus has suggested?  Or can SWITCHER be disabled?  It seems Grass is in an unusable state for me without the XDRIVER (Even if I don't use the GUI; I cannot start a monitor).
Markus, would I search and replace it in just the SWITCHER.c file?
Neteler wrote:
> > Hi all,
> > On Sat, Nov 18, 2000 at 06:39:51PM -0800, Jeshua Lacock wrote:
> > > The XDRIVER24 module fails to compile because the module is dependent on the switcher.c that also fails to compile.  Here's the log:
> > > SWITCHER.c: In function `xalloc':
> > > SWITCHER.c:1369: conflicting types for `malloc'
> > > /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:121: previous declaration of `malloc'
> > > SWITCHER.c:1369: warning: extern declaration of `malloc' doesn't match global one
> > > SWITCHER.c:1369: conflicting types for `realloc'
> > > /System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:125: previous declaration of `realloc'
> > > SWITCHER.c:1369: warning: extern declaration of `realloc' doesn't match global one
> > > make[2]: *** [OBJ.powerpc-apple-darwin1.2/SWITCHER.o] Error 1
> > > make[1]: *** [all] Error 2
> > > Any ideas?
> > Jeshua, could you try to replace all "malloc" with "G_malloc"?
> > If o.k., we should check the entire CVS for malloc. I recently
> > changed r.flow on that, seems to work o.k.
> > Markus
Thanks guys,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
