[GRASS5] Win32 configure.
Mike Thomas mthomas at gil.com.au
Sat Nov 18 16:57:04 EST 2000
Hi all.
One of the problems with building on Windows is that the configure script
doesn't work well.
Q 1.
By inspecting configure.in, I notice that a check should be done for rpclib
in the XDR part as follows:
XDRLIB=
if test -z "${XDRLIB}"; then
AC_CHECK_LIB(sun, xdr_int, XDRLIB=-lsun)
fi
AC_CHECK_LIB(nsl, xdr_int, XDRLIB=-lnsl)
fi
AC_CHECK_LIB(rpclib, xdr_int, XDRLIB=-lrpclib)
fi
AC_SUBST(XDRLIB)
As I haven't been able to get autoconf to work on my computer, could someone
please do this and check it in?
Q 2.
Also, I happen to keep my X headers and libraries in /usr/local/X11r6.4
which doesn't get picked up by configure.  Maybe what I really need to do is
move them elsewhere rather than expecting configure to do this.
Is there a recommended location to put them on Windows?
Cheers
Mike Thomas.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
