[GRASS5] ps.map and -fwritable-strings
Markus Neteler
neteler at geog.uni-hannover.de
Fri Nov 17 04:42:45 EST 2000
Hi all,
as Eric reported that the ps.map Vector-problems seems to
be fixed/non-existing, I will remove all these bugs reports
and also the hint in
src/CMD/generic/POST_INSTALL.sh
Hope this is o.k. with everybody!
Markus
PS: A google search tells us about such problems at least in the past:
http://gis.itc.nrcs.usda.gov/archive/GRASS-output_dir/msg00017.html
On Sat, Nov 04, 2000 at 10:48:21AM +0100, Radim Blazek wrote:
> Hi,
> I wanted to fix writable-strings in ps.map. I walked through source
> and found 8 pointers to string constants but program never writes into
> these strings.
> Does anybody know where writable-strings should be, how was discovered
> that problem is in writable-strings, how to simulate problems or why should be
> problem on Linux only?
> Radim
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
