[GRASS5] Re: ps.icon
mlennert at club.worldonline.be mlennert at club.worldonline.be
Wed Nov 15 08:23:28 EST 2000
> Hi Moritz,
> right now I have added the correct parser to
> ps.map.
> On Wed, Nov 15, 2000 at 12:26:14PM +0100, mlennert at club.worldonline.be wrote:
> > Hi,
> > In Grass-CVS, I have trouble with ps.icon:
> > typing 'ps.icon' gives me:
> > Usage: ps.icon <filename>
> > typing 'ps.icon <filename>' gives me:
> > Usage:
> >   ps.icon
> >     (This command must be run interactively)
> > Calling it from TclTkGrass gives the same results.
> What to do:
> #remove the old stuff:
> cd /usr/local/grass-5.0b
> (or where your GRASS lives)
> find . -name 'ps.icon' -exec /bin/rm -rf {} \;
I had trouble with TclTkGrass after that, since the module was also removed. I
updated the TclTKGrass src tree and compiled it then it worked...but I hope I
haven't removed other files I need...
> #get the update (src)
> cd src/ps.map/ps.icon
> cvs update
> gmake5
> gmakelinks5
> Then it should be o.k. Thanks for notifying!
I can launch it, but only interactively (is that what's wanted ?), but there
seems to be a bug.
I had to comment out line 50 in the main.c for it to work, otherwise it just
exited...
Moritz
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
