[GRASS5] New MacOS X compilation errors
Justin Hickey jhickey at hpcc.nectec.or.th
Sun Nov 12 21:53:12 EST 2000
Hi Eric
"Eric G . Miller" wrote:
> Hmm, the compiler doesn't deal with empty "default:" statements in a
> switch properly???  Try removing the line above that has the empty
> default statement and see if it works then.  If it does, I'll remove
> it from the CVS version (but it's really a compiler bug).
May I suggest adding a "break;" statement as the "default:" action? The
compiler is probably expecting a C expression (ie something that ends
with a semicolon) and finding the "end switch" brace bracket instead.
Besides, it is good programming practice to always include a break
statement for the default case.
And, in general, please do not remove legitimate code from the CVS
source files. If there is a bug in a particular compiler that it cannot
parse legitimate ANSI C code, then a FAQ should be created for that
compiler with a work around solution. We should not change legitimate
code in the source files for a compiler or system bug.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
