[GRASS5] New MacOS X compilation errors
Jeshua Lacock jeshua at SierraMaps.com
Sun Nov 12 02:08:32 EST 2000
Greetings,
Markus - I downloaded the CVS snapshot, thanks for making it available.
First of all, the configure script cannot find my Tcl/Tk libraries -
I compiled and tested them on my OS.  After fooling around for a
couple hours I gave up on it.  My Tcl/Tk libraries are installed in
/usr/local/
It looks like the configure script looks for Tcl/Tk 8.0.5 and not
8.0.5.a, so I tried adding the the .a to the logic - but no go. The
script finds the X windows and open GL stuff fine.
I install Tcl/Tk 8.0.5.a, should install a different version?
The CVS snapshot seems to be missing some files that were are present
in the beta 8 build.
Mainly speaking the "sys/msg.h" file required source/libes/raster
A little side note: with the build 8, I have been using ./configure
-host apple-powerpc-nextstep3
Note that ALL of the following modules worked fine in the beta 8
build. Here is a look at the errors in the shell script for the first
few modules (using the CVS snapshot):
GRASS GIS compilation log
Start of compilation: Sat Nov 11 21:21:42 PST 2000
Errors:
Compilation error in module: src/libes/raster (ignored)
Compilation error in module: src/libes/gis (ignored)
Compilation error in module: src/libes/coorcnv (ignored)
Compilation error in module: src/libes/vect32/georef (ignored)
Compilation error in module: src/general/init (ignored)
Compilation error in module: src/display/devices/CELL (ignored)
Compilation error in module: src/display/devices/XDRIVER (ignored)
Compilation error in module: src/display/devices/HTMLMAP (ignored)
Compilation error in module: src/front.end (ignored)
Compilation error in module: src/libes/dbmi/clients (ignored)
Compilation error in module: src/display/d.3d (ignored)
Compilation error in module: src/display/d.area (ignored)
Compilation error in module: src/display/d.ask (ignored)
Compilation error in module: src/display/d............
etc....
__________________
Here are the errors in more detail copied from the terminal window:
io.c:5: header file 'sys/msg.h' not found
make[1]: *** [OBJ.powerpc-apple-darwin1.2/io.o] Error 1
GISGEN failure at STEP: src/libes/raster
readsites_xyz.c:164: illegal expression, found `}'
make[1]: *** [OBJ.powerpc-apple-darwin1.2/readsites_xyz.o] Error 1
GISGEN failure at STEP: src/libes/gis
make[1]: *** No rule to make target
`/Users/jeshua/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a',
needed by `all'.  Stop.
GISGEN failure at STEP: src/libes/coorcnv
cc:
/Users/jeshua/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a:
No such file or directory
make[1]: *** [/usr/local/grass-5.0b/etc/geo.reg] Error 1
GISGEN failure at STEP: src/libes/vect32/georef
cc:
make[1]: *** [/usr/local/grass-5.0b/etc/set_data] Error 1
GISGEN failure at STEP: src/general/init
cc:
make[1]: *** [/usr/local/grass-5.0b/driver/CELL] Error 1
GISGEN failure at STEP: src/display/devices/CELL
connect.c:6: header file 'sys/msg.h' not found
make[2]: *** [OBJ.powerpc-apple-darwin1.2/connect.o] Error 1
make[1]: *** [all] Error 2
GISGEN failure at STEP: src/display/devices/XDRIVER
cc:
/Users/jeshua/grass/src/display/devices/lib/LIB.powerpc-apple-darwin1.2/driverlib.a:
cc:
make[1]: *** [HTMLMAP] Error 1
GISGEN failure at STEP: src/display/devices/HTMLMAP
cc:
make[1]: *** [/usr/local/grass-5.0b/etc/front.end] Error 1
GISGEN failure at STEP: src/front.end
make[1]: *** [/usr/local/grass-5.0b/etc/bin/main/cmd/db.columns] Error 1
GISGEN failure at STEP: src/libes/dbmi/clients
cc:
/Users/jeshua/grass/src/libes/LIB.powerpc-apple-darwin1.2/libraster.a:
cc:
make[1]: *** [/usr/local/grass-5.0b/etc/bin/main/cmd/d.3d] Error 1
GISGEN failure at STEP: src/display/d.3d
cc:
cc:
make[1]: *** [/usr/local/grass-5.0b/etc/bin/main/cmd/d.ask] Error 1
GISGEN failure at STEP: src/display/d.ask
etc......
THANKS!
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20001111/ddfa13b8/attachment.html
