[GRASS5] Re: grass windows build
John Huddleston jhudd at lamar.colostate.edu
Sat Nov 11 09:21:59 EST 2000
Hi Markus,
Sorry if I sounded irritated about the build system changing
and lashed out at Linux.  That was not the intent.  Grass is
a large system and it takes quite a while to build unattended.
If a failure occurs then it takes more of my time to figure
out what failed.  Since my time is short this hand editing
of Gmakefiles is a bother.  Building Grass5 for windows
used to be a clean process; now it takes much more time.
John Huddleston
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: "John Huddleston" <jhudd at lamar.colostate.edu>; "grass5 developers list" <grass5 at geog.uni-hannover.de>
Sent: Saturday, November 11, 2000 4:44 AM
Subject: [GRASS5] Re: grass windows build
> Hi John,
> [cc to grass5]
> On Fri, Nov 10, 2000 at 06:10:44PM -0700, John Huddleston wrote:
> > Markus,
> > Regarding the pruning, removed files, etc., I seem to remember
> > an email from Bernhard this past summer about how you keep
> > two CVS repositories.   If this is the case, it would be possible
> > for me to do the update and miss some of the "pruning"
> > operations   How do you manage to keep two CVS repositories
> > in sync?     Yes, I did do the appropriate options on the cvs
> > command.
> up to now we have one CVS repository. Later we will open the
> 5.1 repository for the "new GRASS". I guess the 5.0 tree
> will get somewhat sleepy then.
> [new Makefile system]
> > > But you could get it from
> > > Eric Mitchell   <emitchell at altaira.com>
> > > in a package. Maybe you can test it and discuss improvements with
> > > Eric to have them already in when 5.1 is started.
> > I would be happy to test out the makefile system.  Years ago
> > I wrote a Makefile builder for our Unix development teams.
> > It included a slick dependency checker for the source files.
> > If we included a "utility" section in grass, I would be happy
> > to add that to our system.
> This sounds very interesting. Perhaps the "makefile professionals"
> here could discuss this idea?
> Kind regards
>  Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
