[GRASS5] BUGS: r.null on reclass, would mess up original...
Markus Neteler neteler at geog.uni-hannover.de
Mon Nov 6 09:32:25 EST 2000
On Sun, Nov 05, 2000 at 08:55:56PM -0800, Eric G . Miller wrote:
> In BUGS, it lists as [RC] the inability to run r.null on reclass rasters.
> The problem is, if r.null was run on the reclass raster it would alter
> the original and any other reclass rasters of the original.  So, there are
> two basic approaches, let the user make a raster out of the reclass that
> isn't a reclass (e.g. `echo 'newmap = reclass' | r.mapcalc`) or have
> r.null do this for them.  With the second, a new raster has to be made
> and what do you name it?  If you name it the same as the reclass and
> blow away the reclass, is that okay?
> IMHO, this "bug" isn't a big deal and should be downgraded or removed.
Hi Eric,
sounds reasonable... I have downgraded it to non-RC. Perhaps r.null
should just print out a useful message how to make a full map of
a reclassified map, or better, do this job itself (optionally) and
ask for a new map name in this case.
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
