[GRASS5] flex/lex, compatibility
David D Gray ddgray at armadce.demon.co.uk
Thu Nov 2 14:07:13 EST 2000
Andreas Lange wrote:
> Hi,
> can we make flex a requirement for compiling of GRASS5?
> The problem is now that some modules can be compiled with either flex or
> lex, but one module uses an option "%option lex-compat" which is not
> recognized by standard lex.
> Under Linux everything is fine, as flex is always installed, but with
> Solaris and IRIX some machines have a standard, old-fashioned lex
> installed.
> Alternatively we could change the module/lex file, but this would
> require some investigation on the side-effects.
> Do you have other ideas?
There are some other possible incompatibilities. Sometimes lex is used
standalone for reading config or ascii data files (see mif.l in new
v.in.mif module). This uses `exclusive start states' heavily which also
are said to be incompatible with some other lex variants. I think this
is less aproblem with newer versions of the various lex's but it might
still be good to standardise on one (flex).
Regards
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
