[GRASS5] Gmakefile guru wanted for html/Gmakefile
Markus Neteler
neteler at geog.uni-hannover.de
Mon Oct 30 16:45:20 EST 2000
Dear all,
to get the MAN generating running from HTML, a
Gmakefile guru is wanted for html/Gmakefile.
An approch is checked in, but it is not running yet.
The idea (after useful correspondence with Eric Mitchell)
- copy the html pages to $GISBASE/html
- generate the MAN files within the sources
- using the timestamp compare function of make to generate
only missing/changed MAN pages from HTML
- copy the man/cat stuff to it's final location in
$GISBASE/man as usual for g.manual
This should speed up the process comparing to the interim
version active last week.
I would be glad to get this running for 5.0stable. Unfortunately
I am not very familiar with Gmakefiles of this level (a bit
more complex than common Gmakefiles). So help is desired :-)
Thanks in advance
Markus
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
