[GRASS5] CELL->FP converting
Markus Neteler
neteler at geog.uni-hannover.de
Mon Oct 30 12:14:01 EST 2000
Hi Huidae,
On Fri, Oct 27, 2000 at 03:43:20AM +0900, Huidae Cho wrote:
> Hi developers,
> Here are some efforts for easy converting CELL to FP.
> Please check these sources and give me a hint :-)
> This module simply shows raster map's values.
> There are three functions and two data types.
> is_null_value() can be used for CRAY instead of G_is_null_value().
> value2str() is used to print values of various type of raster.
> cpvalue() copies src[scol] to dest[dcol].
> RASTER_PTR union may free us from complicated typecasting.
> RASTER_MAP_PTR has raster map type and it's data.
> Just try. :-)
It seems to work fine! But generally the functions should
follow the GIS library name convention:
G_is_null_value(), ...
Do you think your new functions could become part of the
GIS library and simplify GRASS raster programming?
If so we would have to check for conflicts with existing
G_is_null_value() code. But generally such simplification is
very welcome!
Would these function be sufficient to update r.watershed to FP?
Kind regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
