[GRASS5] list of modules with interface problems
Markus Neteler neteler at geog.uni-hannover.de
Mon Oct 30 06:09:10 EST 2000
Hi there,
On Sun, Oct 29, 2000 at 07:34:55PM +0100, Andreas Lange wrote:
> Hi 2 all,
> while reworking the test suite (dejagnu) (should work now) i found some
> modules not reacting correctly to the "help" parameter on command line.
> I added these modules with a short description to the BUGS file.
> Some modules do produce "garbage" output with the
> "--interface-description" flag, which makes the output fail parsing with
> a xml parser. For your information here the list of modules:
> {m.lulc.USGS} {Mlulc.read} {Mlulc.USGS} {v.surf.rst} {v.out.atlas}
> {v.in.dxf2} {v.in.dxf} {v.in.atlas} {s.surf.rst} {r.weighted.cn}
> {r.resamp.rst} {r.random} {r.out.rlc} {r.mapcalc} {r.flow} {r.colors}
> {m.in.stf1.db3} {m.in.pl94.db3} {i.tape.mss.h} {i.gensigset} {g.list}
> {d.where} {d.rhumbline} {d.paint.labels} {d.colormode}
Here some comments:
{m.lulc.USGS}  old "parser" (GRASS 3.x), needs update
{Mlulc.read}  can we deprecate this module in src.contrib?
                (already in src/misc/!)
{Mlulc.USGS}  can we deprecate this module in src.contrib?
{m.in.stf1.db3}  old parser, needs update [can we deprecate this module?]
{m.in.pl94.db3}  old parser, needs update [can we deprecate this module?]
{r.weighted.cn} old parser (GRASS 3.x), needs update
{r.out.rlc} : old parser (GRASS 3.x), needs update [can we deprecate this
              module?]
{r.mapcalc} : problem is parser, no idea to fix this
{v.out.atlas}  just fixed by Markus.
{v.in.atlas}  just fixed by Markus.
{s.surf.rst}  problem is in output of references (Helena ?):
               -> should have extra flag
{r.resamp.rst}  problem is in output of references (Helena ?):
{v.surf.rst}  problem is in output of references (Helena ?):
{r.flow}   problem is in output of references (Helena ?):
{r.random}: needs to get parameter sensivity:
             -> see d.zoom for useful implementation
Here the help parameter seems to be o.k. (for me):
{r.colors}      problem?
{i.tape.mss.h}  problem?
{i.gensigset}   problem?
{g.list}        problem?
{d.where}       problem?
{d.rhumbline}   problem?
{d.paint.labels}  problem?
{d.colormode}     problem?
{v.in.dxf2}    problem?
{v.in.dxf}     problem?
So it might be an XML-problem (hi Jan).
So far my short report
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
