[GRASS5] xml interface description
Jan-Oliver Wagner jan at intevation.de
Tue Oct 24 12:33:26 EDT 2000
Dear GRASS developers,
I have checked in a new parser.c with the ability
to print out a xml interface description.
The argument for this is --interface-description.
I have also implemented a coarse wxPython program
that loads a xml interface description and builds
a simple dialog. Code is ugly, but it works.
A next milestone of our work towards integration
into OSSIM (which is base on wxWindows)
includes an improved implementation.
The wxPython programm is attached. You need to
have Python, wxPython and python-xml to run it.
Fairly easy to install, at least on my Debian GNU/Linux.
I have also attached a screenshot for those who
don't want to deal with python right now.
The next step is to go thorugh several commands and
look for special behaviour and special types
of parameters. That will partly contribute to
the effort on harmonizing parameters.
Cheers
	Jan
Jan-Oliver Wagner               http://intevation.de/~jan/
Intevation GmbH	              	     http://intevation.de/
FreeGIS	                               http://freegis.org/
#! /usr/bin/python
from wxPython.wx import *
from xml.sax import saxexts
from xml.sax import saxlib
from os import system
ID_RUN   = 10
ID_CANCEL= 11
ID_PARAM_START = 900
ID_ABOUT = 101
ID_EXIT  = 102
VSPACE = 4
HSPACE = 4
MENU_HEIGHT = 30
STATUSBAR_HEIGHT = 30
ENTRY_HEIGHT = 20
STRING_ENTRY_WIDTH = 300
BUTTON_HEIGHT = 30
BUTTON_WIDTH = 100
grass_task = { 'name' : 'unknown', 'lines' : 0, 'params' : [] }
def normalize_whitespace(text):
    "Remove redundant whitespace from a string"
    return string.join( string.split(text), ' ')
class processTask(saxlib.HandlerBase):
    def __init__(self):
        self.inDescriptionContent = 0
        self.inDefaultContent = 0
        self.inValueContent = 0
    def startElement(self, name, attrs):
        if name == 'task':
            grass_task['name'] = attrs.get('name', None)
        if name == 'parameter':
            self.param_description = ''
            self.param_default = ''
            self.param_values = []
            # Look for the parameter name, type, requiredness
            self.param_name = attrs.get('name', None)
            self.param_type = attrs.get('type', None)
            if type == 'flag':
                grass_task['lines'] = grass_task['lines'] + 1
            else:
                grass_task['lines'] = grass_task['lines'] + 2
            self.param_required = attrs.get('required', None)
        if name == 'description':
            self.inDescriptionContent = 1
        if name == 'default':
            self.inDefaultContent = 1
        if name == 'value':
            self.inValueContent = 1
            self.value_tmp = ''
    def characters(self, ch, start, length):
        if self.inDescriptionContent:
            self.param_description = self.param_description + ch[start:start+length]
        if self.inDefaultContent:
            self.param_default = self.param_default + ch[start:start+length]
        if self.inValueContent:
            self.value_tmp = self.value_tmp + ch[start:start+length]
    def endElement(self, name):
        # If it's not a parameter element, ignore it
            grass_task['params'] = grass_task['params'] + [ { "name" : self.param_name, "type" : self.param_type, "required" : self.param_required, "description" : self.param_description, "default" : self.param_default, "values" : self.param_values, "value" : '' } ]
            self.param_description = normalize_whitespace(self.param_description)
            self.param_default = normalize_whitespace(self.param_default)
        if name == 'value':
            v = normalize_whitespace(self.value_tmp)
            self.param_values = self.param_values + [ normalize_whitespace(self.value_tmp) ]
class mainFrame(wxFrame):
    def __init__(self, parent, ID, w, h):
        wxFrame.__init__(self, parent, ID, grass_task['name'],
            wxDefaultPosition, wxSize(w, h))
        self.CreateStatusBar()
        self.SetStatusText('Enter parameters for ' + grass_task['name'])
        menu = wxMenu()
        menu.Append(ID_ABOUT, "&About",
                    "Information about GRASS-GUI")
        menu.AppendSeparator()
        menu.Append(ID_EXIT, "E&xit", "Terminate the program")
        menuBar = wxMenuBar()
        menuBar.Append(menu, "&File");
        self.SetMenuBar(menuBar)
        self.panel = wxPanel(self, -1)
        p_count = 0
        l_count = 0
        while p_count < len(grass_task['params']):
            title = grass_task['params'][p_count]['description']
            if grass_task['params'][p_count]['required'] == 'no':
                title = "[optional] " + title
            grass_task['params'][p_count]['value'] = grass_task['params'][p_count]['default']
            if (len(grass_task['params'][p_count]['values']) > 0):
                wxStaticText(self.panel, -1, title + ':',
                    wxPoint(HSPACE, l_count * ENTRY_HEIGHT + VSPACE + p_count * VSPACE), wxSize(-1, -1))
                l_count = l_count + 1
                wxComboBox(self.panel, ID_PARAM_START + p_count, grass_task['params'][p_count]['default'],
                    wxSize(STRING_ENTRY_WIDTH, -1),
                    grass_task['params'][p_count]['values'], wxCB_DROPDOWN)
                EVT_COMBOBOX(self, ID_PARAM_START + p_count, self.EvtComboBox)
            if ((grass_task['params'][p_count]['type'] == 'string' or
                grass_task['params'][p_count]['type'] == 'integer' or
                grass_task['params'][p_count]['type'] == 'float') and
                len(grass_task['params'][p_count]['values']) == 0):
                wxTextCtrl(self.panel, ID_PARAM_START + p_count,
                    grass_task['params'][p_count]['default'], wxPoint(HSPACE, l_count * ENTRY_HEIGHT + VSPACE + p_count * VSPACE),
                    wxSize(STRING_ENTRY_WIDTH, ENTRY_HEIGHT))
                EVT_TEXT(self, ID_PARAM_START + p_count, self.EvtText)
            if (grass_task['params'][p_count]['type'] == 'flag'):
                wxCheckBox(self.panel,ID_PARAM_START + p_count, title,
                    wxSize(-1, -1), wxNO_BORDER)
                EVT_CHECKBOX(self, ID_PARAM_START + p_count, self.EvtCheckBox)
            p_count = p_count + 1
        wxButton(self.panel, ID_CANCEL, "Cancel",
            wxPoint(2 * HSPACE, VSPACE + l_count * ENTRY_HEIGHT + p_count * VSPACE + 3 * VSPACE))
        wxButton(self.panel, ID_RUN, "Run",
            wxPoint(2 * HSPACE + BUTTON_WIDTH + HSPACE, VSPACE + l_count * ENTRY_HEIGHT + p_count * VSPACE + 3 * VSPACE)).SetDefault()
        EVT_MENU(self, ID_ABOUT, self.OnAbout)
        EVT_MENU(self, ID_EXIT,  self.OnCancel)
        EVT_BUTTON(self.panel, ID_CANCEL, self.OnCancel)
        EVT_BUTTON(self.panel, ID_RUN, self.OnRun)
    def EvtText(self, event):
        grass_task['params'][event.GetId()-ID_PARAM_START]['value'] = event.GetString()
    def EvtCheckBox(self, event):
        if (event.Checked()):
            grass_task['params'][event.GetId()-ID_PARAM_START]['value'] = 'checked'
        else:
            grass_task['params'][event.GetId()-ID_PARAM_START]['value'] = 'not checked'
    def EvtComboBox(self, event):
    def OnRun(self, event):
        cmd = grass_task['name']
        p_count = 0
        errors = 0
        errStr = ""
            if (grass_task['params'][p_count]['type'] != 'flag' and grass_task['params'][p_count]['value'] == '' and grass_task['params'][p_count]['required'] != 'no'):
                errStr = errStr + "Parameter " + grass_task['params'][p_count]['name'] + "(" +grass_task['params'][p_count]['description']  + ") is missing\n"
                errors = errors + 1
                if (grass_task['params'][p_count]['value'] == 'checked'):
                    cmd = cmd + ' -' + grass_task['params'][p_count]['name']
            if (grass_task['params'][p_count]['type'] != 'flag' and grass_task['params'][p_count]['value'] != ''):
                cmd = cmd + ' ' + grass_task['params'][p_count]['name'] + '=' + grass_task['params'][p_count]['value']
        if errors:
            self.OnError(errStr)
        else:
            system(cmd)
    def OnError(self, errMsg):
        dlg = wxMessageDialog(self, errMsg, "Error", wxOK | wxICON_ERROR)
        dlg.ShowModal()
        dlg.Destroy()
    def OnCancel(self, event):
        self.Close(false)
    def OnAbout(self, event):
        dlg = wxMessageDialog(self, "This is a sample program for\n"
                              "GRASS command interface parsing\n"
                              "and automatic GUI building.",
                              "About", wxOK | wxICON_INFORMATION)
        dlg.ShowModal()
        dlg.Destroy()
class GrassGUIApp(wxApp):
    def OnInit(self):
        self.w = HSPACE + STRING_ENTRY_WIDTH + HSPACE
        self.h = MENU_HEIGHT + VSPACE + grass_task['lines'] * ENTRY_HEIGHT + VSPACE  + BUTTON_HEIGHT + VSPACE + STATUSBAR_HEIGHT
        frame = mainFrame(NULL, -1, self.w, self.h)
        frame.Show(true)
        self.SetTopWindow(frame)
        return true
# find out the command to run
if len(sys.argv) > 1:
    print "usage: <grass command> --task-description | " + sys.argv[0]
else:
    # parse the interface decription
    parser = saxexts.make_parser()
    dh = processTask()
    parser.setDocumentHandler(dh)
    parser.parseFile(sys.stdin)
    parser.close()
    # Create the application
    app = GrassGUIApp(0)
    app.MainLoop()
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20001024/472bf178/d.rast.png
