[GRASS5] proposal for a grass command interface description for
automatic GUI building
Jan-Oliver Wagner
jan at intevation.de
Tue Oct 24 02:59:18 EDT 2000
Hi Andreas,
On Tue, Oct 24, 2000 at 12:18:35AM +0200, Andreas Lange wrote:
> I have only to add that some modules in GRASS 5.0 need updating/fixing
> to work as expected.
The user interface description would benefit from some face lifting
within the GRASS commands. I'll need to go through a number of commands
(for the grass-ossim bridge I will focus on raster commands)
and look for problems.
> First there should be some standardization on the interface, eg. we have
> to define when to use "file=" and when "input= output=" etc.
> This is not required for the XML parsing, but for the user. And should
> be done as soon as possible.
I have seen the recent postings about this issue. The standardization
would benefit any kind of GRASS user interface.
I am really happy to see people work on this matter.
> If you find modules that do not work as expected, please tell me as i
> will try to update them (already fixed g.setproj).
Sure :-)
Cheers
Jan
Jan-Oliver Wagner http://intevation.de/~jan/
Intevation GmbH http://intevation.de/
FreeGIS http://freegis.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
