[GRASS5] proposal for a grass command interface description
forautomatic GUI building
Tim Cera
timcera at earthlink.net
Mon Oct 23 08:28:45 EDT 2000
Jan-Oliver Wagner wrote:
> My main ideas for the way to go are
> * GRASS programs can be asked for the parameter description
> * parameter description is based on XML.
This is great! I would add one additional criteria. That the XML is
kept in a seperate file so that changes could be made to the interface
without re-compiling. Something like
$GISBASE/task_description/r.basins.file.xml. This would allow very
rapid language changes (German, French, ...etc.) and user customizations
- just replace/edit the XML files.
Any developed interface systems should use the --task_description (I
changed the internal "-" in your original message to an "_") instead of
the raw XML. Maybe --interface_description, since a user will probably
never type it? And then change the XML directory name to match.
take care
tim cera
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
