[GRASS5] Debugging modules ...
Eric G . Miller
egm2 at jps.net
Sun Oct 22 05:39:07 EDT 2000
On Sat, Oct 21, 2000 at 06:45:01PM +0200, Andreas Lange wrote:
> Hi Eric, Hi David,
> thanks a lot for the information. I can run now DDD from within a grass
> session. But i have the problem with r.reclass that i can not do any
> input. Will investigate this further another time.
Are you using an execution window? Should spawn an xterm for
input/output. Unfortunately, if you restart the program, you have to
specify this again.
#! /bin/sh
# ppp-address: What's my Internet Address for ppp0 ?
/sbin/ifconfig ppp0 | grep 'inet addr:' | sed \
's=.*inet addr\:\([0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}\.[0-9]\{1,3\}\).*=\1='
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
