[GRASS5] Debugging modules ...
Eric G . Miller
egm2 at jps.net
Fri Oct 20 22:24:52 EDT 2000
I did the following and was able to run a module with DDD (uses gdb).
In grass/src/CMD/head/head set the following (don't use any
optimization)
COMPILE_FLAGS = -g
LDFLAGS =
Then, for whatever module delete the OBJ* dir and rerun gmake5. Then
run gdb (or DDD in this case) on the executable in
<path>/grass-5.0b/etc/bin/<main | contrib>/cmd/<module> . The
executable in <path>/grass-5.0b/bin/ is not what you're interested in.
/bin/sh ~/.signature:
Command not found
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
